  #1
Old June 19th, 2007, 02:30 PM
PW2 PW2 is offline
Default 1974 Evinrude 9.9 Exhaust housing
I got this motor from someone after it overheated,and I had to resurface the head. I also took aff the lower unit to replace the impeller and check it out. So far, so good, but I checked the water flow thru the block by hooking it up to a garden hose, and I found a huge water leak in the exhaust cover plate. Not sure exactly if it is just a gasket leak or if the cover plate is broken or split, but here is the problem. I can't get a wrench on the bottom right hand bolt under the motor mount on this thing. I'm really hoping I don't have to remove the powerhead just to remove this cover plate, but I'm not sure I see an alternative. Any ideas on how to fabricate a wrench or something so I don't have to remove the whole powerhead?
  #2
Old June 19th, 2007, 06:55 PM
PW2 PW2 is offline
Default Re: 1974 Evinrude 9.9 Exhaust housing
Bump--I'm really hoping someone will come up with a way I can remove that cover without having to remove the powerhead to do it!
  #3
Old June 19th, 2007, 07:07 PM
mikesea mikesea is offline
been a while,but,if i recall there are some bolts in the pan that if removed will allow the pan to drop enough to get at bolts,likely 3/8 or 7/16.the bolts you are trying to get at are 3/8 again if i recall,you might get a 3/8 flex head socket ,1/4 drive,crastsman has them,not many make 1/4 drive flex,if your lucky thatmight do the trick itself,dont know if its a salt water used motor,but,those bolts are notorious to stick and often break,go slow,one other trick,ive seen people drill a hole through pans and weld them up,epoxy em up,not me,but in a pinch it can work,theres lots of rubber plugs out there that will repair it too
  #4
Old June 19th, 2007, 11:34 PM
PW2 PW2 is offline
No, it's not a salt water motor. All the other bolts have come out easy, and I have no reason to think this one will be any different
I'll look again tomorrow to see if there is anything that I can drop down to make it accessible. Those are 7/16" head bolts holding that cover on. I've had to buy a 5/16" and a 3/8" flex drive sockets (1/4" drive) for other outboard projects, but I don't think a 7/16" will work in this case.
I've pretty well resigned myself to removing the powerhead. If it is anything like the 6 hp Johnson that I just did that on, it sounds a lot worse than it actually was--hopefully that will be the case this time too-we'll find out tomorrow.
Thanks
  #5
Old June 22nd, 2007, 05:59 PM
PW2 PW2 is offline
Ok, I finally got that exhaust cover off, but there is no way I'm going to get it back on without removing the powerhead. I've got everything ready to remove the powerhead, but there seems to be 4 phillips head screws on the upper lower unit holding the exhaust housing, just below the cowling, and it appears that they have to be removed before the powerhead will come off.
I can't get those screws to budge. I've been beating on it with a hammer and an impact driver to no avail, and before I go the route of getting ever bigger and better hammers, I thought I'd ask someone if they had any better ideas??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1974 Johnson 70 gear case housing puller blueboat1 Johnson & Evinrude Outboards 2 June 23rd, 2003 12:26 PM
searching for exhaust housing for 9.5 evinrude jasonandidie9000 Johnson & Evinrude Outboards 0 May 27th, 2003 06:05 PM
looking for a exhaust housing for my 9.5 evinrude jasonandidie9000 Johnson & Evinrude Outboards 2 May 24th, 2003 09:09 AM
Johnson 1974 throttle control housing edhead Johnson & Evinrude Outboards 15 January 10th, 2003 08:14 AM
1974 Mercury 150 Extention Housing drzucco Mercury & Mariner Outboards 0 November 25th, 2002 05:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
