I have a 2001 Sea Ray Sundancer 240 with a brand new 305 in it. Took it out and put about 10 hours on it since new engine, ran great, no problems. Trailered it under cover and took it out 2 weeks later and the thing wont start. Starter turns it over but I have found upon further investigation that A., Im not seeing any fuel coming out of the 2 throttle body injectors, and B., there is no spark coming from the coil. Its almost like there is no power being sent to the ignition or fuel injectors. I can hear the fuel pump run and I have reset the kill switch several times, it seems to be working fine. All of the fuses are fine and I cant find any loose wires anywhere. I tested power to the coil by pulling one of the wires to the distributer and there was no spark when I held it close to the cap. I also put a test light to the 2 posts on the coil and turned the key to the on position and there was no power. Does anyone have any idea what could be wrong here?? Would a bad coil cause all of these problems including no fuel being shot into the throttle body? I would think that it should at least still shoot fuel into the engine. Also, what exactly is that thing called a Mercathode that sits on top of the engine? Mind you, this happened while the boat sat under cover. It worked fine last time out. Any suggestions would be great, Thanks!!
