I have been having increasing trouble starting my '96 70hp Johnson (J70TLEDA). I can pull start the motor, but it will not start with the key (starter turns over, occasional pop of motor firing with smoke out exhaust). Once the motor is warm, it starts easily with the key all day. I hate starting the day pull starting by boat in front of guests, it doesn't really instill confidence in the trip!
I replaced the battery, the plugs and plug wires and still had no start with the key. I disconnected the yellow/red wire from the starter solenoid and attached a remote switch. With the ignition in run, the remote switch started the motor instantly!
I did a continuity test on the key switch and everything seems fine. I checked continuity on the yellow/red wire from switch to solenoid and it checked out. I reattached the yellow/red wire to solenoid and tried again but nothing. I ran a temp wire from the starter switch to the solenoid. The motor starts fine without the yellow/red wire attached but won't with it attached.
The wiring diagram shows this yellow/red wire going to the power pack. Could the power pack be my problem or is there something else I should check?
Mike
Mike
