reelfishin
- Mar 19, 2007
- 3,043
I am in the process of replacing the helm and steering cable on an 18' open boat that will most likely have a 70 HP Johnson motor. I have several other boats, all similar but this is the only one that had the steering cable that goes throught the tube in the motor with a steering rod. The others all have fixed cable ends and steer the motor by way of a pivot bolt. Is there some rule of thumb as to which style should be used on any particular boat?
My one boat has a 65HP Merc and uses the single bolt type of steering, this boat is only slightly larger with only 5 more HP, can I use this much simpler steering set up? It certainly eliminates rusted steering tube problems.
