Well I was hoping someone had this issue and has a solution.
Mercruiser 7.4 with Weber Carbs, It is really hard to start. New everything
compression great new plugs wires rotor cap, carbs rebuilt by a carb "expert". The rebuilder I had used in the past. Engines smoke, stumble hard to start cold, tried adjusting choke idle screws etc. I have seen other threads about this but I really need some help!!!
