Flush attachment / tell tale
AEROCOOK
Master Chief Petty Officer
I was getting ready to fire up my 1988 60hp Merc. in the driveway. I attached the flush attachment and turned on the water there was a fair amount of water blowing out the sides of the rubber cups which is normal from what I have read. The problem is that there is no water coming out of the tell tale. Should I expect this or does the motor have to be running in order to pump the water through the engine and out the pisser?
tashasdaddy
Re: Flush attachment / tell tale
engine has to be running, but should only take 5 seconds for it to start peeing. remember no pee no cool. try running weedeater line up the outlet incase critters have made a home there.
