  #1
Old June 18th, 2007, 08:52 AM
Rick K Rick K is offline
Default Carb Adjustment on Yamaha 8
Replaced fuel pump diaphragms and rebuilt carb on my kicker. Put about 10 hours on it, ran absolutely perfectly and then it died. Finally got it going again after 20 minutes of pulling. After reading posts here, I found that the primer bulb is shot, so I'll pick one of those up.
Question is, what is the right adjustment on the idle mixture screw? When I disassembled the unit, I seated the screw, and counted approx 1-3/4 turns or so. I'm sure it was adjusted at one point, but I'd like to have it to spec, then go from there. I want to rule out adjustments as a possible cause of the motor dying.
The Clymer manual I have makes no reference, other than to note the number of turns, etc.
One other question - if, after using the motor all day, shouldn't there be pressure built up inside the gas tank? I don't get that pressure relieving "hiss" outta the tank any more when I loosen the cap.
Thanks
Rick
  #2
Old June 19th, 2007, 03:28 AM
deejaycee_2000's Avatar
deejaycee_2000 deejaycee_2000 is offline
Default Re: Carb Adjustment on Yamaha 8
the tank's ventilation screw must always be open when operating the motor ..... the carb screw setting should be turn inwards to soft stop (be carefull not to brake this off) then outwards 1 and a half turns .... then you can lightly adjust from there, it is best to adjust this when the motor is fully warmed up .....
__________________
__________________________
... THE MAXIMUM HORSEPOWER IS NEVER ENOUGH ...
  #3
Old June 20th, 2007, 04:33 PM
Thanks! I figured it was the old turn-and-a-half deal on the mixture screw, but with no reference in the book, I just needed to make sure... I appreciate your help.
Rick
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Carb Adjustment 1998 C115 Yamaha bayhawk14 Yamaha & Suzuki Outboards 2 October 12th, 2005 06:45 PM
Carb adjustment Meaux Johnson & Evinrude Outboards 4 August 16th, 2005 05:25 PM
Carb. adjustment SUBWAYJO Johnson & Evinrude Outboards 12 January 1st, 2005 12:12 PM
Yamaha carb cleaning and adjustment Millmaker Yamaha & Suzuki Outboards 4 July 29th, 2004 11:49 AM
carb adjustment jessiewigg Yamaha & Suzuki Outboards 8 July 24th, 2003 04:30 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
