  #1
Old June 17th, 2007, 09:26 PM
bermuda8 bermuda8 is offline
Default 2005 Mercury 25 not pumping water
Hi,
I have a 2005 25 merc that worked fine out on the lake (plenty of water coming thru the hole) but came home, put on the ears to flush and water just barely drips out. I can feel air coming out the hole but no water. Of course I immedietly shut the motor off to hopefully avoid any damage. I've searched other threads but haven't seen this exact problem so I don't know anything I can check before taking it in. Any ideas?
Thanks in advance.
  #2
Old June 18th, 2007, 02:22 PM
Default Re: 2005 Mercury 25 not pumping water
I tried running weed wacker string thru the hole but it stops when I get to the elbow bend. Shoudl I take the rubber hose off and try try to run it further?
  #3
Old June 18th, 2007, 02:45 PM
zzzzz zzzzz is offline
you can try compressed air thru the pee tube or a good strong stream of water...have the motor running when you do this so if something is plugging it up it will get flushed right out
  #4
Old June 18th, 2007, 03:08 PM
Do I put the ears on the bottom of the motor when doing this?
Thanks
  #5
Old June 20th, 2007, 07:27 PM
Well I took the motor in and had a new impeller installed but when I got it home tonite it just drizzles water out when idling then shoots it at full stream then back to drizzle - when it drizzles its so hot it burns my hand - what else could it be?
any help would be appreciated. thanks
  #6
Old June 20th, 2007, 10:28 PM
is this normal? after looking at a gazillion posts it looks as if this is normal. I'm just real paranoid about burning the engine up since the 25 hp one don't have a overheat alarm.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury outboard not pumping water mwrBoat Mercury & Mariner Outboards 3 June 23rd, 2009 01:11 AM
7.5 mercury (no water pumping) 308user Mercury & Mariner Outboards 7 April 23rd, 2007 11:25 AM
2002 MERCURY 125 NOT PUMPING WATER ROBERTSTELLJR Mercury & Mariner Outboards 3 June 19th, 2006 01:35 PM
water not pumping mercury burtinski Mercury & Mariner Outboards 1 April 15th, 2003 05:34 AM
Mercury 50 Overheating - No Water Pumping!! Jonathan Morley Mercury & Mariner Outboards 3 September 11th, 2002 02:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
