Repairing Stripped Threads in 75 hp Evinrude Head
I would appreciate hearing if there are some options for repairing the cylinder head on a 75 hp 1977 Evinrude. The Evinrude blew out a spark plug for the second time. The first time was over 12 years ago, which is how long I have owned the motor. At that time the head was tapped and redrilled and a spacer used to accomodate the OEM plug. The second time was last week. The mechanic said the head was in very good shape other than that. I raised question about using an 18mm plug that was compatible with OEM plugs, but that was ruled out. I suggested using JB Weld, but that was ruled out. I even said that I though it might be able to be tack welded, but that was ruled out. Unfortunately, there were no options at the time, other than trying to find a used head. Appreciate any advice or help. WES
