Hi' I am working on a 1985 50 HP Mercury outboard, I am changing the power pack (switch box) CDI 174-56454K1 because after doing a visual inspection the coating started to melt. Also changing the stator because the resistance was not within range. CDI state that if there any voltage on the kill switch it could ruin the power pack. Check with volt meter red terminal to kill switch wire black to ground, turn switch to ON not start there is some minium voltage. Is my ignition switch going bad, has anybody came across this before what will the best procedure to follow. Any input on manner would be greatly appreciated. Thanks
