  #1
Old June 16th, 2007, 01:44 AM
Mano del Sol's Avatar
Mano del Sol Mano del Sol is offline
Default motor height, small fishing boat
On my little 12' Aluminum Starcraft fishing boat my transom is 16 inches top to bottom. The length of my motor from the top of the inside of the mounting bracket to the cavitation plate (if that is what it's called) is 18".
If I move the motor all the way up to where the thumbscrews are against the transom cap thingy I'm still about 1 1/2" below the hull.
Is there any that any of you know to get the motor up higher and should this even make a difference?
I'm still at least a few weeks away from mounting the motor and being able to do anything with the boat but I am a compulsive planner and this is bugging me not knowing!
Thanks!
  #2
Old June 16th, 2007, 02:36 AM
Reel Poor's Avatar
Reel Poor Reel Poor is offline
Default Re: motor height, small fishing boat
Does the engine mounting bracket have holes so you could mount the engine to transom without using the thumbscrews?
__________________
Of those who receive good advice, only the wise will profit from it.
If you need it....Get it
If you want it....Wait
If you have it....Flaunt it
  #3
Old June 16th, 2007, 02:43 AM
No it doesn't. It's just a clamp mount.
  #4
Old June 16th, 2007, 10:25 AM
CATransplant's Avatar
CATransplant CATransplant is offline
Hmm...I can't remember what motor you have for that boat. Typically, the smaller outboards have about an 18" length from transom to cav plate. I'm not sure why that is, but there it is.
Unless the engine you're mounting is going to plane this boat, I wouldn't worry about it. Your boat is the same as mine, I just hang the motor on it and go fishing. Maybe, if I find a 9.9, I'll worry about the mounting height, but for now, it doesn't matter.
You could add an extension to your transom, though, if you really need to. It's been done many times.
  #5
Old June 16th, 2007, 03:39 PM
It's a 10 HP Johnson.
I don't think it's a matter NEEDING to, I just want to get everything installed as best I possibly can while I have it all tore apart. Seems kind of silly to rebuild the carb and ignition on the motor, rebuild and paint the trailer, replace all the wood, and probably end up re-painting the interior of the boat just flop the motor on there and go. I just wanna make sure it's as right as I can get it with what I've got, I don't think I am willing to modify my transom though.
And as I said, I didn't even know whether that 1 1/2" will even be significant.
  #6
Old June 16th, 2007, 08:46 PM
F_R F_R is offline
An old 10hp Johnson, right? Those things were made to run deep. Raise it up as high as you can, it it makes you feel better and see how it works. Put a stick under it on top of the transom for a trial. But take precautions so it doesn't twist off of the transom and go for a swim. It will make a bit of difference in speed, but it also may cavitate. You just have to experiment.
  #7
Old June 17th, 2007, 11:08 AM
I understand. As another poster said, those engines were designed to go on boats just like yours. You might be able to get another couple of miles per hour out of it by fiddling with the height, but that's probably it.
I've had a 10 hp on my boat, which is identical to yours. I mounted it down on the transom, like it was designed for. The boat scooted along very nicely, planing out easily, even with just me in the back seat.
I can't tell you the speed, but it was as fast as I cared to go in a 12' aluminum fishing boat. That's why I'm suggesting that you just hang that motor on the transom, with it sitting right down on the top. Take it out for a spin on the lake.
I'm betting you'll be quite happy with the performance of your tinny.
  #8
Old June 26th, 2007, 05:57 AM
After doing a search I just might make a homemade jack plate thingy. It won't cost me much and it should be easy enough. The only issue I haven't seen in the other posts on this topic is what size and how many bolts to use.
The hull has the four #10 screw holes in it for the transom plate thingy but I suspect that those won't be enough.
  #9
Old June 27th, 2007, 06:18 AM
michiganmarty michiganmarty is offline
Mano,
I also have a 12 footer with the same issue. I added a 1" spacer to the top of the transom. The transom spacer really needed to be taller than 1", but the clamp screws would have run out of transom to clamp to. Without a whole lot of extra work, the 1" spacer was the easy way out.
By the way, the spacer did not make even the slightest bit of difference to how the boat performed. Now maybe if I raised it up until the cav plate was even with the bottom of the hull it would have, but that is an awful strong maybe.
You should seriously consider leaving the boat alone - forget the modifications. If you ever decide to sell the boat, most people will walk away from it since the transom was altered from the original design intent.
Besides, if the motor needed to be that high, I would think Starcraft would have designed it with a taller transom.
  #10
Old June 27th, 2007, 08:08 PM
BF BF is offline
on some older motors without thru hub exhaust, the water pickup is above the cavitation plate. My 25 hp OMC is like that. They need to be run with the cav plate lower than newer motors.
  #11
Old June 29th, 2007, 03:14 AM
Quote:
BF,
Good point. my 28 SPL E-rude is like that as well.
  #12
Old June 29th, 2007, 10:39 PM
Well, not to nitpick but I was never going to modify the transom, just make and install a jack plate.
So, I have read in several threads that those motors were designed to run deep. If this is true then what are the reasons or advantages to running them that deep if a boat will run faster and plane out easier with it higher?
Is it because the water intake is right under the A/V plate?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Motor height set-up on a non pad boat? brownies Prop Questions and Topics 7 April 26th, 2006 06:35 AM
Small Fishing boat for my boys rogerwa Boat Topics and Questions (not engine topics) 15 March 26th, 2005 09:41 AM
Boat Hop.. Motor Height .. and other madness Maximerc Non-Repair Outboard Discussions 4 August 15th, 2003 02:25 PM
Boat Hop .. Motor height ?????? Maximerc Non-Repair Outboard Discussions 23 August 11th, 2003 10:10 AM
What is best/most knowledgable small boat & fishing(fresh) magazine? Heinz CA. Boat Topics and Questions (not engine topics) 11 September 20th, 2002 01:12 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
