**** 1999 25hp Mercury** Lower Unit, Need Info******
Put Lower Unit Back On, After Prop Shaft Swap Out, Now With Motor Off Put In Foward Gear Spin Shaft By Hand Makes Clicking Noise In Foot, Reverse Is Fine, Net Is Fine But In Forward,wont Spin Back And Will Spin Foward With Clicking Noise...
Re: **** 1999 25hp Mercury** Lower Unit, Need Info******
Ok, But On My 1999 Foot I Dont Recall It Doing That, The Foot Parts Now Are From 2004, Shaft And The 2 Gears On The Shaft,i Just Swaped The Hole Shaft, Seals Etc. Thanks. Keep Hearing About Using Shims??? Thanks
