Re: Cooling on 82 60hp Johnson
there are six bolts holding the lower unit, 4 very visible, other 2 where the cavitation plate is (roung thing on top of the propeller). ..one infront of the other..
when you doing all this, put the shifter in REVERSE, then take off the starter to get to the 2 little bolts under the carb holding the shift shaft... there are two little bolts, you only need to loosen one of them, that is horizontal (bolt head is looking at the starter side).
then lower unit will slide right off..
to get to the impeller, just open up the top impeller housing cover, believe its 4 lil bolts holding it, very visible.. then im sure you know what to do after that..
