I have a 89 force 125 need help withtrim tilt problems!
Ian McNeil
My trim tilt motor does not seem to work. I am looking to buy a another one but cant seem to find the hydraulic hausing that goes on the bottom. I took the motor apart and there was some rust on the inside of it and on the contacts. Im pretty sure the motor is bad but cant seem to find anything but the motor. I need to find the peice that all the lines go into and not having much luck. Any info would be greatly appriciated. Is there a way to rebuild this. I know they do not make this any longer so what is my best bet.
Thanks,
Ian
RRitt
Re: I have a 89 force 125 need help withtrim tilt problems!
To my knowledge there is no one selling complete pump assemblies. You can find API motors and valve bodies right here on iboats. They are about $250 each. You can save some money by sending your valve body in for repair. I think API does that for around $200. You can also get motor portion rebuilt by local auto electric shop for about $100. And you can also search ebay for pump assy rebuilds that include both motor and valve body. But I don't think anyone will sell both halves as a single part.
