  #1
Old June 15th, 2007, 11:39 AM
swaghole swaghole is offline
Default Mercury 40 hp - no reverse
I have 1994 Mercury outboard that won't go in reverse. The problem started when I shifted in reverse when slowly moving forward (trying to stop to avoid a rock). I think I revved the motor a little before it fully engaged in reverse. The outboard did a little bit of grinding and some clicking noises and never went into reverse (I did hit the rock - only the hull, not the motor).
So, after, I could not put the outboard in forward of reverse. I shut down the motor and trimmed it out of the water to have a look. Nothing to see, so I tried again. This time, the outboard went in forward gear ok, but I completly lost reverse. When I try to put it in reverse, it does a clicking/grinding noise that increases in frequency as the motor revs faster.
So, any idea on what broke?
Thanks.
  #2
Old June 18th, 2007, 09:35 AM
kingfish62 kingfish62 is offline
Default Re: Mercury 40 hp - no reverse
Have you checked the linkage? I had a siimilar problem and found that I broke a piece in the linkage that serves as a push pull mechanism. I ordered a new part from the dealer but used a hose clamp until it arrived..
  #3
Old June 19th, 2007, 08:49 AM
Where do I start looking for the linkage? Will I see something if I pull the cover off the motor? Is it possilble it's something in the prop that broke?
  #4
Old June 19th, 2007, 09:14 AM
Swag, I'm no expert and I suppose that yes it could be somthing in the lower unit however, the first place I would look is under the cowl. The linkage should be located on the right side of the engine looking from inside the boat or left from outside. If you can get someone to help you shift it in and out of forward and reverse while you look at it you should be able to tell if everything is connected properly. As I said the only time I ever lost a reverse gear it was a broken connecter in the linkage. Real simple fix.. Good Luck
  #5
Old October 4th, 2009, 11:17 AM
leedsboy leedsboy is offline
just wondered if anybody could help!! my engine is a mercury 9.9 hp 1987 model. it works fine going forward and in neutral, but when i put it in reverse it makes the right sound and everything but its not making the prop spin fast enough!!!
please please please can anybody help!!!!
  #6
Old October 4th, 2009, 11:37 AM
Ruggybuggy Ruggybuggy is offline
You already posted this and now hijacking a thread. Post more info in the previous thread as suggested.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1964 mercury won't reverse jamandaranch Mercury & Mariner Outboards 1 May 14th, 2007 03:12 PM
Mercury 25h.p won't go in reverse chris grooms Mercury & Mariner Outboards 4 February 22nd, 2005 11:02 AM
Reverse on 40 h.p. Mercury KurtAyres Mercury & Mariner Outboards 1 November 9th, 2003 05:41 AM
84 mercury 115 NO REVERSE 72INVADER90HP Mercury & Mariner Outboards 2 June 1st, 2003 09:31 AM
Goes into reverse on land but not into reverse on water.. Mercury 1970 650cc Thu y2jericho Mercury & Mariner Outboards 5 May 12th, 2003 03:54 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
