hey f inscreenname...
tie_one_on
What's the update on your engine swap? I hope everything turned out better than you hoped. I lost the link to your website, can you repost it.
Thanks, good luck.
Oh yeah, your websitelike is a bit difficult to read with the background, other than that I really to follow your saga.
f_inscreenname
Re: hey f inscreenname...
Been some ups and some downs. I have made a couple test drives and found my prop needed some real work so its off to the prop shop. Just trying to work out all the bugs. Had the motor out 2 times alone just to get all the bolt on pieces to fit inside the box. I picked a couple MPH and and about 5 to 600rpm (thats why my prop is in the shop) and that is pretty much a stock motor. Next winter is when all the "cool stuff" (exhaust, heads, ......) will be bought for it.
http://www.supernova19.com/motor_build_ii_at_supernova19_com.htm
or you can get there by the links below.
