  #1
Old June 14th, 2007, 06:46 PM
snitz70 snitz70 is offline
Default Slow leak
I bought a '91 bayliner 2050 capri last year. I've had it out a few times and noticed that there is a small leak that i can't seem to find. The bellows are all new, the motor does not leak, re siliconed the tie down brackets, swim ladder bolts, etc... It still leaks.
What i have now found is that on the sides and rear of the boat there is a chrome trim piece. If i look inside, there seems to be dirt streaks by the rivets and bolts for that trim. It is also wet underneath a few of them, so i think i found the leak. Question is, how can that be leaking? The trim is above the water line. Has anyone else run into this? I'm not sure if taking off the trim to re-seal it would be opening a can of worms, of if i should just try siliconing around the rivets.
Any help would be appreciated.
Thanks,
Brian.
  #2
Old June 14th, 2007, 07:10 PM
gcboat gcboat is offline
Default Re: Slow leak
If these are your engine cowling vents you will get some water through them. Going over a wake, turning hard to one side or the other, etc. will introduce water in there. First off DO NOT use any type of silicone. It is an unreliable product and has no business on a boat - period!! 3M makes a good variety of bedding compounds that would be a lot more beneficial and longer lasting. Have you checked your cable bellows? Without having a look it really is hard to give you a definate answer but - again - do not use silicone. I'd be more than happy to send you a list of sealing products that would be a lot better - or go to the 3M web page and take a look around.
  #3
Old June 15th, 2007, 12:04 PM
I don't think it is coming in the cowlings, but could be wrong. What I am talking about is the trim that goes all around the boat. In the pic, you can see the trim going above the swim ladder. That is where it seems to be leaking. Also, by silicone, I mean a marine grade sealant. Can't remember the brand i used. I guess i am used to calling all sealants like that, silicone.
Brian.
  #4
Old June 15th, 2007, 04:48 PM
That trim - or rub rail - is what holds your boat together. FRP boats are made in two pieces, a top ( or cap ) and the bottom. When they are joined together they lock over one another and are screwed through to fasten. When a piece of rubrail is either screwed or riveted on, a piece of rubber, rope, whatever is placed in that. So there you have a whole boat !!! Now, it could be that there is some delamination where the two units are joined. The only way to find that is by removing the rub rail insert and look at the condition of the screws. If loose or not caulked in good then quite possibly could be your problem. Not often - but it does happen - the two pieces (top & bottom ) have pulled apart due to getting slammed into a dock or piling and have a nice chunk missing or cracked. All you need to do is get a hose and start at the stern - with the bow up - and run some water on it. Obviously this is a two person job. Start running the water from the top of the rub rail all along one side, then try to force some water under the rail going the same way as first. If there's a leak you'll find it. If you have the leak narrowed down then just concentrate your attentions there. First top, then bottom. Let us know what you find.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Slow oil leak and oil absorbing pad superpop Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 June 16th, 2006 05:21 AM
Slow water leak into oil rarc Non-Repair Outboard Discussions 3 August 11th, 2004 01:46 PM
Slow Leak FreeBeeTony Boat Topics and Questions (not engine topics) 7 July 3rd, 2004 12:16 PM
77' OMC 175, Slow leak!!! JOHN HARTER Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 June 7th, 2004 07:54 AM
Slow leak longjess Dockside Chat 3 July 5th, 2002 05:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
