Mercury Inboard/Outboard impeller not pumping water. How do I change it on outdrive??
M magnum Recruit Joined May 14, 2007 Messages 2 May 17, 2007 #1 Mercury Inboard/Outboard impeller not pumping water. How do I change it on outdrive??
Haut Medoc Supreme Mariner Joined Jun 29, 2004 Messages 10,645 May 17, 2007 #2 Re: Impeller not pumping water http://www.boatfix.com/merc/Servmanl/6/6covr3.pdf........
180shabah Rear Admiral Joined Mar 26, 2005 Messages 4,995 May 17, 2007 #3 Re: Impeller not pumping water We are assuming that you have verified that your drive shaft is spinning and that you do not have a bad coupler.
stevieray Lieutenant Junior Grade Joined Jul 18, 2006 Messages 1,135 May 17, 2007 #4 Re: Impeller not pumping water Haut Medoc said: http://www.boatfix.com/merc/Servmanl/6/6covr3.pdf........ Click to expand... Also assuming you have an Alpha 1 generation 1 or older The more info you can give...the better answer you will get.
