Alright.....I have a 1973 Johnson 115. I Was having a problem with it sneezing REALLY bad!! I replaced the spark plugs, re-built the carbs, and re-built the fuel pump. After doing all of this it seemed to help out quite a bit with the "sneezing" It used to do it just idling and low speeds and it used to do it constantly. Now it only does it in low speeds....idle seems to be ok. when i have it at mid and full throttle it runs exellent.....just the low speeds when i'm in the no wake zones which are everywhere around here. It sneezed so bad twice it totally stalled. It also seems to run a bit rough but again only at very low speeds....when I give it more throttle the problem seems to go away but then i'm causing wake which is no good. I am going to try and attempt a link & sync....i don't know what else to do. Seems pretty complex to do a link and sync and being that this is my first boat i'm new to all of this. I do have the factory service manual. Any suggestions at all? I really apprecitae you guys helping me out....Just want to get it running right again in time for summer! Also i didn't take apart any of the linkage on the carbs. I kept all of those intact.
Thanks
James
Thanks
James
