Re: 1986 4 HP Johnson head air cooled?
1 0389682
Add to pick list CYLINDER & C'CASE ASSY. 1 7
2 0314951
Add to pick list SCREW, Cyl. to c'case 8 4
3 0304067
Add to pick list PLUG, Large 1 5
4 0307588
Add to pick list PLUG, Small 1 5
5 0322831
Add to pick list SCREW, Center 2 6
6 0323522
Add to pick list WATER DEFLECTOR 1 4
7 0328158
Add to pick list TUBE, Crankcase drain 1 6
8 0300402
Add to pick list TAPER PIN 1 5
9 0328159
10 0314951
Add to pick list SCREW, Mfld. to c'case 4 4
11 0395711
Add to pick list CYLINDER HEAD 1 7
12 0332010
Add to pick list GASKET, Cylinder head 1 2
13 0307471
Add to pick list SCREW, Cylinder head & fuel tank 4 4 Models with Integral Fuel Tank Only
14 0320107
Add to pick list TIE STRAP, Pulse hose 2 1 Models with Integral Fuel Tank Only
15 0324570
Add to pick list MOUNTING BRACKET, Fuel tank, upper 1 7 Models with Integral Fuel Tank Only
16 0302750
Add to pick list SCREW, Cover plate 8 6
17 0386941
Add to pick list SPARK PLUG, Champion L77J4 2 1
17 0387633
Add to pick list SPARK PLUG, Champion QL77J4 2 7
18 0323263
Add to pick list PLATE, Exhaust cover 1 4
19 0323445
Add to pick list GASKET, Cover plate 1 3
20 0324571
Add to pick list MOUNTING BRACKET, Fuel tank, lower 1 7 Models with Integral Fuel Tank Only
21 0326544
Add to pick list NIPPLE, Pulse head to cylinder 1 4 Models with Integral Fuel Tank Only
22 0325881
Add to pick list PULSE HOSE 1 7 Models with Integral Fuel Tank Only
23 0323446
Add to pick list GASKET, Plate to c'case 1 4
24 0314951
Add to pick list SCREW, Cylinder head 0 4
25 0302750
Add to pick list SCREW, Ground 1 6
26 0388941
Add to pick list MANIFOLD, Intake 1 5
27 0323444
Add to pick list GASKET, Manifold 1 4
0388653 0388653
Add to pick list LEAF PLATE ASSY. 1 7 Not Shown
28 0303764
Add to pick list SCREW, Leaf to plate 4 5
29 0314915
Add to pick list LEAF VALVE 2 4
30 0323485
Add to pick list PLATE, Leaf back-up 2 5
31 0385111
Add to pick list CHECK VALVE 1 4
32 0322927
Add to pick list LEAF PLATE 1 5
33 0305344
Add to pick list SCREEN 1 4
34 0330812
Add to pick list SHIM, Leaf plate 2 5
35 0303701
Add to pick list LOCKWASHER, Ground lead 1 4
36 0389554
Add to pick list POWERHEAD GASKET SET 1 7
