I need some help with my 1986 40EL Mariner. With the Outboard in a large garbage can of water, the water pump only seems to work only at higher RPM's. When I go from higher RPM's to an Idle, you can hear a psssssss, and the water flow stops and doesn't return until I rev the motor up again. I removed the lower unit, inspected the impeller, gaskets cover etc., and everything looks ok. I put it all back together and the same happened. The impeller, and all related parts were replaced 2 season's ago and the boat has been used for no more than 4 hours since.
I'm at a loss.....please help!
Thanks!
