help hp and serial#
cr125
hi everybody need help identifying my motor hp i dont have any sn# 1989 bayliner capri and where can i find the sn# motor painted already thanks...:)
roscoe
Re: help hp and serial#
Is this a Force motor?
The model number was only located on an id tag, that was attached to the motor mounting bracket, usually on the starboard side, 3-5 inches below the powerhead.
How many cylinders?
2 cylinders = 40 or 50 hp
3 cylinders = 85 hp
4 cylinders = 125 hp
5 cylinders = 150 hp
MWBROWN
I have a 1984 , 85 hp, and the serial numbers is under the cowling on the drivers side, front corner. Metal tag stamped with serial number rpm and hp. I don't know but this may help.
Mike
cr125
hi guys
first of all thanks for helping me
roscoe,its a 3 cylinder meaning 85hp so ican order parts now you save me lots of time and money .....:)
mike,i will try that under the cowling on the drivers side, front corner and i let you know...
thanks again
roy
roscoe
If the motor is a 1990 or newer.....
a 3 cylinder would be a 70 hp with 1 carb, or a 90 hp with 3 carbs.
cr125
hi again dont have any idea what year is this motor i found a # m612649 on the motor the the sn#of the boat end 89 and the motor is 3cylinder 3 carb.the motor is mounted inside the boat the botom piston ring is rectangle and the top ring is like cone shape the bore size or cylinder size is 3"5/16 i belive this is 3"312 . so i hope this information will help us .
thanks alot
