  #1
Old June 13th, 2007, 12:37 PM
Neal0o Neal0o is offline
Unhappy 1969 Mercury 9.8 HP 110 Out board Starting Problem
I'm at my wits end. I have a mercury that is getting the best of me. Its nearly impossible to start when cold. I also have the service manual.
I have replaced all the gaskets in the carb - cleaned - etc.. My problem is that when you apply full choke it appears that the carb is being flooded. It get so much fuel that it leaks out of the carb intake.
I have just ordered a new inlet need/seat and gasket kit. Am i safe to assume that i prolly have a float adjustment and/or bad inlet needle? I really appreciate any feedback.
I wanna go Fishing
Neal0o
  #2
Old June 13th, 2007, 03:44 PM
Harker Harker is offline
Default Re: 1969 Mercury 9.8 HP 110 Out board
Or a bad fuel pump or plugged idle tube or your "start" setting on the tiller slipped. Does it run well after you DO get it started?
  #3
Old June 13th, 2007, 05:15 PM
Quote:
Once started it runs like a dream. Makes good power. If full choked and pull the rope it gets a whole lotta fuel in the venturi. So much that it leaks out the intake. I got it to crank a couple of times with the motor in FWD and almost full power. I know that once its started (warm) it starts on the first pull.
float adjustment? new seat? I suspect the fuel pump is good, though i haven't tested it yet like the manual calls for testing it.
Thanks for the help!!
Neal0o
  #4
Old June 13th, 2007, 05:47 PM
My 67 sqirts a lot of gas in when the choke is closed too...but it starts easy when cold. When it is warmed up and running good, idle it down all the way whith the tiller...then, turn the tiller to "start"..does it pick up quite a few rpms? If you have the manual, look at adjusting this..sometimes it slips out of adjustment and the throttle is too low to keep it going. Good luck
  #5
Old June 14th, 2007, 03:45 PM
Could anyone recommend other things that i should look for? If indeed i'm not getting too much fuel and it still won't start what else could be a factor? These little carbs are touchy lol
viva la mercury.
Neal0o
  #6
Old June 15th, 2007, 12:42 PM
A new float, seat and needle won't hurt anything..adjusting the float setting on these is a bit of a bear. I had about the same thing on mine where the only way it would run was full throttle in fwd and it just barely would run..got a new in box fuel pump off ebay and it fixed the whole shmear....the idle screw had to be out almost two turns also instead of the one turn out the manual says to do. Make sure you have the top of the float chamber on the corect way too because it has a vent hole that needs to be in the right position.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
year of mercury out board bob the builder Mercury & Mariner Outboards 11 September 16th, 2009 12:03 AM
115 mercury out board tacklebox Mercury & Mariner Outboards 3 August 15th, 2006 03:33 PM
80s mercury out board / having troble cav103176 Mercury & Mariner Outboards 1 July 24th, 2005 12:32 PM
1969 Johnson out board 55hp, wont prime billy_s7music Johnson & Evinrude Outboards 10 February 21st, 2002 10:27 AM
1980, 70HP Mercury Out Board - HELP!!! Sea Nymph Mercury & Mariner Outboards 1 August 30th, 2001 10:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
