  #1
Old June 13th, 2007, 11:45 AM
cancan cancan is offline
Default 68 Evinrude shifter problems
Okay so I dropped the lower end on my 1968 55hp Triumph to change water impeller and had to remove the solenoid housing and pull solenoid out to remove the gearcase fully. I changed the impeller and put everything back together and some how I've lost neutral and reverse. Gearcase was in neutral when I disassembled lower unit. Is there a seperate fluid to go in the solenoid housing or does the gear oil fill that chamber. Any ideas
Signed; I'm so CLOSE
  #2
Old June 13th, 2007, 12:10 PM
F_R F_R is offline
Default Re: 68 Evinrude shifter problems
In the first place that was the wrong way to do it. The right way is to disconnect the cable at the top end. No need to monkey with the solenoids. But now that the deed is done...
To answer your specific question, the gear oil fills the whole thing. However they found that it does not like to go into the solenoid chamber so they added another vent plug for that as a running design change. BUT that has nothing to do with your problem. The solenoids don't have to be in oil to work.
Secondly, the gearcase could not have been in neutral when you took it apart. It will ALWAYS be in forward gear when it is not running. Unless the shifter piston is stuck in the oil pump. But that is another story.
I don't know what else to tell you except to again say that the motor has to be running and it has to have oil in it. The oil does the shifting. The solenoids only open and close some oil control valves. The shift switch in the remote control operate the solenoids.
  #3
Old June 13th, 2007, 12:15 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
To remove the lower unit, you'rer supposed to disconnect the shift wires at the starboard side of the powerhead, NOT to remove the solenoids from the lower unit.
In installing the solenoids as you've done, you have missed the oil pump lever hole with the bottom portion of the solenoid assembly.
Remove the lower unit properly, drain the gearlube, then remove the solenoid assembly and re-install it so that the bottom of the solenoid rod assembly is where it belongs.
  #4
Old June 13th, 2007, 01:56 PM
Okay I've found the gear disconnet wires. Now a dumb question I've disconnected them, so when I drop the lower unit again shoud I hook them to a wire or string to pull them back up through the exhaust housing.
  #5
Old June 13th, 2007, 01:57 PM
kauboy kauboy is offline
I'll betcha Joe is spot on. When I took my '67 55 apart, I had purchased a solenoid kit to replace what I thought were bad solenoids. Turned out to just be a broken wire, but I decided to throw the new solenoids in anyways. I did notice that he rod that the solenoids engage when they actuate must fit properly into the hole that Joe referred to. I remember that I was just able to close the housing but that it wasn't as tight as when I took it off. So I inspected further and found that I too had missed this hole. You have to use a light touch to feel when the rod drops in there. When it does, the housing will close and seal nicely.
BTW, my lower unit doesn't have another vent plug for that chamber. Is oil even getting in there? Could this create an air lock? Or is it okay to forget about it?
EDIT: You responded before I could submit :-)
Yes, it is good practice to tie those wires with a longer extension of something so that when its time for reassembly, you can just pull the whole lot back through the housing.
I don't know if it was a good thing or a bad thing, but when I dropped my lower unit, I found that someone had installed a two prong plug for easy disconnect of the solenoid wires. That was nice of them, considering I couldn't for the life of me get those wires to pull down through the unit.
  #6
Old June 13th, 2007, 02:06 PM
Thanks for the info maybe I'll install the lower disconnect myself...
  #7
Old June 13th, 2007, 03:42 PM
F_R F_R is offline
Hey, remember that's underwater. I wouldn't do any splicing unless there was no other way out and even then only with super good insulation. Water and exposed electric wires don't mix.
  #8
Old June 13th, 2007, 03:43 PM
Just be sure to check, test, and re-test to ensure that you are hooking them up right. If you mess it up, you may be puttering along one day, kick it into neutral, and start cruising backwards.
EDIT:
Good point F_R. Mine were pretty good, but better never hurts.
  #9
Old June 13th, 2007, 03:55 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
i took a small dowel and just tapped the wire at the grommet, and they come right out.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #10
Old June 14th, 2007, 05:01 PM
Thanks for the help guys. I dropped it down and found the solenoid end was not lined up right, so I reajusted and alls well. I don't know what I would do without six or seven more hands to get this thing on the water....
Graham
  #11
Old June 14th, 2007, 07:53 PM
Glad to hear you got it going!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Recognise this shifter? And other problems... bobuk Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 May 13th, 2007 11:15 AM
shifter problems tjstrike Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 12 April 30th, 2006 06:58 AM
shifter linkage problems cwoodruff Johnson & Evinrude Outboards 1 March 22nd, 2005 01:18 PM
Merc 140 shifter problems cleon11 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 August 9th, 2004 05:29 PM
Shifter Problems. merc_500 Mercury & Mariner Outboards 8 June 29th, 2004 10:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
