  #1
Old June 12th, 2007, 02:31 PM
rockyracoon rockyracoon is offline
Default 1987 Evinrude 70 hp smoking
My 70 hp rude smokes a lot at start up. It runs strong and compression is 130 across all 3 cylinders. VRO is orignial and still operational. Is there a way to address this? Will putting in a new VRO improve this? Also when I squeeze the bulb, gas leaks out of the pump. Is this a ruptured diaphragm? It doesn't seem to leak when running. Thanks for any help.
  #2
Old June 12th, 2007, 03:42 PM
hoeser's Avatar
hoeser hoeser is offline
Send a message via MSN to hoeser
Default Re: 1987 Evinrude 70 hp smoking
I'm not sure why your fuel pump is leaking but I can tell you that a newer VRO pump actually mixes more oil at lower speeds than the older pumps. You should however still consider replacing the pump - it is probably old enough to be highly susceptible to failure due to alcohol (ethanol) in the gas. I'm not sure in what year they started to compensate for this by adding alcohol resistant rubbers in the pumps, but I'm pretty sure it was way later than 1987.
  #3
Old June 12th, 2007, 03:51 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Welocme to iboats, i would upgrade or go to premixed gas/oil. pump should not be leaking. are you sure the hose is not leaking going into the pump. have you ever done a decarb on the engine. excess carbon build up, could be causing the smoking.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #4
Old June 12th, 2007, 06:11 PM
jtexas's Avatar
jtexas jtexas is offline
if gasoline comes out the pump, then it needs rebuilding. That will cause excess smoke as the VRO cycles more when you have a fuel leak, you get more oil in the mix.
__________________
"It's all about the tools." -- myself
"Poets talk about 'spots of time,' but it is really fishermen who experience eternity compressed into a moment. No one can tell what a spot of time is until suddenly the whole world is a fish and the fish is gone. I shall remember that son of a b**** forever." -- N. Maclean
  #5
Old June 13th, 2007, 08:19 AM
Kevin W Kevin W is offline
I would agree with Jtexas it most likely has a hole in the diaphram and a rebuild is in order.
I would make sure it is definately the pump and not a fuel hose connection.
your choices are rebuild or replace the VRO or change over to a premix by getting a regular pump.
there are tons of articles about switching over the VRO.
  #6
Old June 13th, 2007, 09:26 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
And when you get that taken care of, use synthetic or semi-synthetic oil and you will see much less smoke. I used Pennzoil Semi in my 70 Rude and it made a big difference...
__________________
Rick
"Boating is Life...All the rest is just Details"
  #7
Old June 18th, 2007, 02:23 PM
Thanks everyone for the responses. It is definitely not leaking from a hose connection. When the bulb is pumped, it leaks from the end of the oil chamber at the top of the pump. I will be changing it out soon.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Smoking 90 Evinrude 90 h.p. car5car Johnson & Evinrude Outboards 6 March 12th, 2007 10:09 AM
97 70HP Evinrude smoking using oil BASSTARD1 Johnson & Evinrude Outboards 0 June 1st, 2006 06:10 PM
77 25hp evinrude smoking tdr9499 Johnson & Evinrude Outboards 4 January 18th, 2004 05:59 AM
6 HP Evinrude Smoking Pikey2574 Johnson & Evinrude Outboards 9 January 15th, 2004 05:11 AM
93' 25 evinrude won't idle and is smoking Disco Superfly Johnson & Evinrude Outboards 3 June 14th, 2003 04:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
