Re: 150HP Mariner Dies once on plane
sounds like a low fuel issue. most common cause would be tank vent not open enough so it can suck some fuel, but not enough to keep it running wide open. old fuel line and or worn line connections. if it starts to die and you pump up the primer bulb and it picks up again, you've narrowed it down. next choice would be faulty fuel pump.
