  #1
Old June 11th, 2007, 08:27 PM
heavyset heavyset is offline
Default 2001 evinrude ficht dies. then starts right back up
taking my boat for a cruise, I have twin 2001 150 fichts. The starbord motor dies all of a sudden. The motor fires right back up like there is nothing wrong, a few minutes later it will die again. After the motor dies it will start right back up, like nothings wrong so on and so forth. I replaced the fuel filters but it is still acting up. The motor will plane off and idel perfect but it just quits just like that. Any advice would be great. Thanks
  #2
Old July 28th, 2007, 11:12 PM
taschwartz taschwartz is offline
Default Re: 2001 evinrude ficht dies. then starts right back up
Check your electrical connects to the ECM module. I had a problem with a loose GND wire to the module that drove me crazy. It would crank, idle fine and then die when powering thru 2000 RPM. Tighted the screw down on the GND wire problem solved.
Hope this helps,
Tom
  #3
Old July 29th, 2007, 12:51 AM
seahorse5 seahorse5 is offline
While the motor is idling with the cover removed, very carefully tap the computer box (EMM) with the shank of a screwdriver. Tap, not pound. Sometimes a bad circuit inside the computer will stop the motor. Also inspect the wiring harness for rubbing or chafing, especially around the top stb. side of the motor where it may contact the top of the block.
Oftentimes you can't find the problem and have to either exchange the EMM with your dealer for a new or rebuilt one, or have it fixed by DFI Technologies.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
87 evinrude 40 hp starts and dies musky55303 Johnson & Evinrude Outboards 1 June 6th, 2007 09:11 PM
starts and dies evinrude 70 firstimer Johnson & Evinrude Outboards 2 February 25th, 2005 02:15 PM
boat dies and then starts back up after an hour hunzy12 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 July 11th, 2003 05:35 AM
'77 Evinrude starts, runs, dies, why? louise Johnson & Evinrude Outboards 1 August 9th, 2002 03:24 AM
75 HP, 1961 Evinrude Starts and Dies ???? oldevinrude Johnson & Evinrude Outboards 4 March 11th, 2002 06:52 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
