Hi, I am re-building my carbs off of my 1973 Johnson 115. Everything is going smoothly thankfully since this is my first time!! Just a quick question....when I went to take out the slow speed screw plugs they were finger loose all 4 of them. Just wondering if this is some kind of adjustment screw or what because I see that you can gain access to them just by taking the air silencer cover off but I can not find anything in my manual that says anything like that. Also the gaskets that are inbetween the carbs and the air silencer are not in the best shape but don't look terrible. My carb kits do not include these gaskets...are these critical to replace?
THanks a bunch
James
By the way...I am re-building these carbs because it coughs every now and then at slow speed and I was told it sounds like the carbs need a re-build but I haven't really found and plugged orfices or anything...looks pretty spotless. I also re-built the fuel pump.. Just trying to get everything tip top for summer.
THanks a bunch
James
