  #1
Old June 11th, 2007, 01:14 AM
hoobs hoobs is offline
Send a message via MSN to hoobs
Exclamation my 93 bayliner has a leak in it.....
Hi guys I am new to this forum, and hope to learn from the best! I have a 93 capri bayliner and I have just noticed That when I travel at a 30mph -40mph cruising speed I get water coming in from just under the drivers side dashboard to the left under the steering wheel. I have also noticed that when I make a sharp right at times it comes in faster.....Anyone have suggestions? I can't see any (holes) in the boat. Thanks. Bart
  #2
Old June 11th, 2007, 08:57 AM
gcboat gcboat is offline
Default Re: my 93 bayliner has a leak in it.....
Look at the underside of your rubrail. If there are any missing pieces of sealant it will cause water to enter. Most all FRP boats are made in two pieces - top and bottom - and joined underneath the rubrail with screws. If the sealant is missing or a couple of screws have worked thenselves loose then you will have that problem. A proper fix would be to remove your rubrail and check all the screws then rebed the entire thing making certain that the two "caps" are sealed as well. Not a difficult project at all. Just use some good sealant - not silicone - and snug the screws. Replace the rubrail and rebed - drink a cold beverage of your choice and admire your handywork.
  #3
Old June 11th, 2007, 06:52 PM
Thanks....!!! Now would my speedo not working at the same time as this be co-insidental?
  #4
Old June 11th, 2007, 09:21 PM
No, your speedometer is in no way connected to or affected by your other problem. Usually if you blow some air back through the system it might dislodge anything that could be blocking your water flow - if it is a pitot system.
  #5
Old June 12th, 2007, 02:51 PM
I will check it out tonight...and I will let you know..Thanks for your help thus far
  #6
Old June 15th, 2007, 09:31 AM
eeboater's Avatar
eeboater eeboater is offline
Hoobs,
What type of power do you have on your boat? I have a 91' Capri with a Merc Alpha one and my speedo wasn't working. Turns out, the speedo was operated by some sort of feature in the outdrive. After further examination, I noticed a hose hanging loose under the outdrive up near the stearn of the boat. I is difficult to picture from describing it - but if you need help locating it, I can get a photo.
Sean
  #7
Old June 17th, 2007, 03:31 PM
I have the 4.3 merc v6 and I checked under the steering column last night and noticed a rubber hose hanging loose under it? up in behind where the speedo gauge is....I am baffeled.
  #8
Old June 20th, 2007, 08:07 PM
So you have a pitot system. That rubber hose will run from the speedo on your dash to the pickup tube on your transom. The pressure of the water is what gives you a relative M.P.H. They are not really accurate to a degree but better than nothing I guess. Take that hose and cut off about 1/4 to 1/2 inch - if you have the room. Replace it on the speedo ( there will be a hose pick up on it - a male adaptor ). That will allow the water to push into the unit allowing it to give you M.P.H.
  #9
Old June 21st, 2007, 12:41 AM
JAL51974 JAL51974 is offline
where the hose attaches to the speedo use a plastic zip tie to make sure it is sealed tight on it, that worked for me. Any kinks or tears in that hose will cause it not to work too.
__________________
"SeaDog"
1985 Bayliner Capri 1950 BR
AQ125a/270
Even a bad day on the water is better than a day at work!
  #10
Old June 24th, 2007, 07:09 PM
It looks like one hell of a place to get into.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Help! Carburetor Fuel Leak - 1989 60HP 2 Carb, 3 Cylinder fuel leak from Jet wgstelz Mercury & Mariner Outboards 1 September 23rd, 2006 07:51 PM
Bayliner eugene1e Boat Topics and Questions (not engine topics) 1 June 25th, 2006 10:52 PM
Power Steering Leak and using stop leak jurasicjet Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 June 11th, 2006 01:33 PM
bayliner cuddy bow leak intrepid Boat Topics and Questions (not engine topics) 7 February 24th, 2004 09:07 AM
Lower Unit Leak??? Doint know if I have a leak jeff7599 Johnson & Evinrude Outboards 3 April 1st, 2003 03:55 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
