I have a 1966 Mercury 9.8 hp outboard that runs great. It had fuel pump troubles but that is now solved. There is a small hole on the left side of the lower unit right above and in front of the gearcase bulge. After running the motor in a tank, there is a kinda foamy oily substance that comes out of there. The same foamy oil comes out through the prop exhaust. It is not a large amount of oil and it stops leaking rather quickly. Is this just unburnt/excess fuel/oil mix?
Also, sometimes the carb leaks fuel before and during running. I'm not really sure where the fuel comes out, but it is a considerable amount. When it is leaking, the engine dies. Other times it does not leak and it runs fine. Is this some sort of relief "vent" or is it a seal problem?
Thanks in advance for any help.
