  #1
Old June 10th, 2007, 10:30 PM
B Money B Money is offline
Default Yamaha Oil Injection Problem
Remote oil tank will not pump to engine. Float switches are all good. Motor magnets came loose but glued back and motor runs in emergency mode. Will fill with emergency switch. Alarms sound and engine rpms drop as designed when low oil is detected but remote tank does not fill the engine tank. Motor has 6.3vdc when low on oil. It has 12.4 when emergency switch is operated. There is 12vdc to ground from the brown wire at motor. Does this sound like a computer problem. I have checked all I can back to the connector going into CDI unit. I can find nothing bad? Anyone have a clue?
  #2
Old June 10th, 2007, 10:46 PM
Default Re: Yamaha Oil Injection Problem
2002 OX66 250 Saltwaterseries2
Forgot the important stuff.
Was reading other posts and I don't think I have the trim sensor.
If I do it is not hooked up to gauges and I have been using motor for quite some time now.
  #3
Old June 10th, 2007, 11:54 PM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
shoot me a PM with e-mail addy and i will send u the troubleshooting guide
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #4
Old June 11th, 2007, 09:55 AM
Thanks to JUSTINTIME for his help and trouble shooting guide. Ran out first thing this morning and checked the trim sensor..actually I did not get any readings on my meter...ohm's. Exercised the thing drained the tank and turned on the key. Voila' I'm pumping again. Will check the switch very good befopre I head back offshore. Thanks again everyone. Justintime if you are ever in S.FLA I owe you a dolphin / sailfish trip.
  #5
Old June 15th, 2007, 02:09 AM
JUSTINTIME's Avatar
Quote:
sweet
if u are ever in the sf area, i will get u on some butt's and salmon!!
__________________
  #6
Old June 18th, 2007, 06:53 PM
Johnshan1 Johnshan1 is offline
I am having the same issues! Where do i start?
  #7
Old June 18th, 2007, 10:38 PM
JUSTINTIME's Avatar
shoot me a pm and i have the guide for u
__________________
  #8
Old June 25th, 2007, 09:47 PM
channelsurfer channelsurfer is offline
JUSTINTIME,
I am having the same problem, Sent you a PM with my email
Thanks
John
  #9
Old June 25th, 2007, 10:02 PM
Rsergeant Rsergeant is offline
I just had the same problem with my 88 200 etxgs everything was fine except the motor was fried in the remote tank, and also I thought the sensor in the engine tank was bad. Turns out the float was sticking on the engine tank also, this was not letting the pump turn on, or everything was low and the pump ran until it was burned out. I'll never know but make sure you check the motor in the remote tank with 12v direct, ohm meter both the remote float and the engine float and then start checking wires. My motor (I may not be right on this but I am almost sure that it doesn't have trim position or it doesn't work.) Best of luck it was almost three months and alot of searching on here before I found my problem.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha oil injection problem fastkenny Yamaha & Suzuki Outboards 2 October 12th, 2004 06:22 AM
Yamaha Oil Injection Problem RangerJer Yamaha & Suzuki Outboards 28 September 3rd, 2004 03:06 PM
Yamaha 115 Oil Injection Problem yamaha 115 Yamaha & Suzuki Outboards 6 September 28th, 2003 05:21 PM
YAMAHA 250 Oil Injection Problem freeman-c Yamaha & Suzuki Outboards 2 May 20th, 2003 05:36 PM
yamaha 150 oil injection problem jig Yamaha & Suzuki Outboards 5 May 18th, 2003 09:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
