Re: 1973 Thunderbird stringers
You do not need any timber, just a form (shape) to layup over. Timber was used in early boat construction because it was cheap and readily available.
They were also made with standard wax / poly resins for the most part. Problem is this is not 100% waterproof, and over time water will pass through into the timber and it rots.
When repairing these older craft you might like to consider using an epoxy resin as it bonds better to old poly resins than new poly resin. using a standard resin the mechanical bond relies on the keying the roughened surface, a single bond mechanism; an epoxy has a mechanical and a secondary chemical bond and can be 30 to 40% stronger.
Also note that an epoxy repair is lighter and stronger than standard resin pound for pound. Standard resin to Chopped Strand Mat ratio is close 3:1, that's 3 parts resin to one part CSM; the ratio for epoxy resin and cloth (Not CSM) is closer to 1:1.
Using standard CSM with an epoxy resin is a huge waste and not at all strong. The binder in standard CSM will not dissolve and the voids ratio is way too high resulting in a weaker and brittle repair / construction.
When replacing ribs we use a closed cell foam with well rounded tops and a fillet on both sides made with micro-fibres or closed cell balloons mixed with epoxy resin.
I hope this helps.
Avagoodweekend......
