Droll
- Jul 30, 2003
- 514
Decided to make the converting before this season, getting tired of the prop slipping............
My existing lower unit should be 100%, but it's still slipping .
It got all new seals
Correct oil ( no water )
New electric wires ( ALL the way )
Good battery ( good charging )
New hub/clutch spring ( whole forward assembly, bought from Joe R )
Tested multiple propellers.
My conclusion....my engine got to much power for this LU/boat/propeller.
( 15 foot boat, running 40 miles at 5000 rpm, turning a 10" x 12" propeller )
Just finished rebuilding a manuel lower unit, currently working on the shift linkage....BUT I am missing the "shaft & arm assembly" part #379240, anyone ?? .
I am reusing the exhaust hosing from the 90, just drilled out the plug.
Had to do some cutting/welding on the lower front motor cover to enable the shift lever, got it working nicely .
Arne Kjetil
Arne Kjetil
