Re: Stripped spark plug threads in block, How to fix
Most good shops are equipped to fix that, Chris.
The most common fix is a device called a Helicoil, a steel insert. Your SP hole is drilled out and rethreaded and the Helicoil is screwed in. Your plug now screws into the helicoil.
A better device is called a Time-sert, an alloy sleeve threaded to screw into the enlarged, threaded hole and expanded to lock it in there.
The Time-sert is better because the alloy sleeve conducts heat from the spark plug at a rate closer to the original alloy block, allowing the spark plug to operate normally, rather than hotter than stock.
The drilling and threading can be done without dismantling the engine, but it requires expert use of special techniques to keep shavings out of the cylinder.
