1965 Tilt/Trim Leak
CPO_05
Got this boat and it has leaking issues (sat for a few years). Discovered the port line out of the transom can not be tightened enough to stop a leak, as well as the starboard cyclinder leaks everywhere. Inspection found the threads stripped in the piece that the lines hooks up to, will replace.
Broke down the cyclinder, trying to inspect the seals, but am having trouble figuring out how to take them out. Can someone post some instructions on this if they have delt with it? Would like to get the boat on the water by Sunday if possible....
Don S
Re: 1965 Tilt/Trim Leak
The oem Service manual is going to be the only information available for that old engine/drive.
You need manual #1, it covers engines, drives, and everything else for that year. The Merc PN for the manual is 90-68648
