  #1
Old June 9th, 2007, 01:33 PM
DavidP DavidP is offline
Default My Regal 176 Valanti
Hi,
I'm new in boating and recently bought my first boat. It's a 1999 Regal 176 Valanti (SE) with a 2003 3.0l 135 hp Mercruiser engine. Beside some minor stuff which I hope to fix by myself with the help of iboats the boat is in a great condition.
I love this boat and it's fun to speed around
Does someone has some infos about weak parts of this boat? I have some cracks in the ski compartment. How can they occure? Someone has a wiring diagram for this boat? I ordered a manual @ Regal but it will take till beginning of next month since they have to reprint it
David
  #2
Old June 15th, 2007, 09:39 AM
Mischief Managed Mischief Managed is offline
Default Re: My Regal 176 Valanti
The cracks in the locker on mine were caused by a complete lack of fiberglass cloth on the marine plywood locker sole. The cloth only extended down the sides of the locker and stopped after it helped join the locker sides to the sole. I added cloth and resin to mine and sprayed it with a tan rattle can. It was messy, but cheap and easy work and it will help keep the boat in good shape for years.
  #3
Old June 16th, 2007, 10:46 PM
Here is a pic of the cracks http://forums.iboats.com/attachment....7&d=1181405436
I will check first for signs of rot below that area and then decide what to do. Without signs of rot I will go the easy way else I will replace the whole area
  #4
Old June 19th, 2007, 11:36 AM
Mine was worse than yours. I was able to remove most of the cracked resin with fingers alone and the rest came out with a putty knife and then a sander. There was no rot under it but there was moisture. I dred it out thoroughly with constant airflow and heat before I glassed it over. I had no problems after that and hear no complaints from the current owner, who keeps in touch.
  #5
Old September 7th, 2008, 06:45 PM
drlightnin drlightnin is offline
MY first boat is a 94 Regal Valanti 176 SE, my whole floor was cracked like your ski locker is. The carpet was rotten when I got the boat. I resealed the entire floor and ski locker with GluvIT epoxy to protect the plywood and put new carpet in. I didn't repaint the ski locker, I might do that someday.
  #6
Old November 10th, 2008, 04:14 PM
-alfy- -alfy- is offline
blast from the past, but anyone else have this boat?
  #7
Old June 22nd, 2009, 04:18 PM
UpStateSteve UpStateSteve is offline
I have a 1993 Valanti 176 SE. (Just acquired it recently)..I have found the exact problem with mine as well in the ski locker. In my scenario, not only did the bulk of the resin come out with my bare hands, so didn't the plywood underneath.
Fixing it proved pretty easy. I use my dremel with high speed cutting wheel to remove any remaining wood, resin from the ski locker sole. I then cut 1/2 plywood to the appropriate shape, applied a couple coats of poly resin to the back and edges and laid it in place. Once in place, i used 4 inch wide strips of glass mat on all seams, corners to tie in place. I followed that up with 2 more layers of glass matt and resin the extended 4 inches up the sides of the locker and the entire sole...
Topped it off with gray paint, reinstalled the drain screen and was back in the water a day later.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Regal? mfaust2807 Boat Topics and Questions (not engine topics) 5 May 3rd, 2007 11:56 PM
Im on my 3rd Regal and......... crazy charlie Regal Boats 7 December 1st, 2005 07:48 AM
Regal valanti mid-cabin verses Ambassador? jstubble Boat Topics and Questions (not engine topics) 1 May 3rd, 2005 03:34 AM
26' Regal Valanti - New to Boating bigtone Boat Topics and Questions (not engine topics) 13 January 21st, 2005 04:01 AM
99 Regal tjkprop Boat Topics and Questions (not engine topics) 2 July 19th, 2003 07:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
