  #1
Old June 9th, 2007, 09:28 AM
TP Bayliner TP Bayliner is offline
Default Electrical Problem
I have a 2000 Bayliner Bowrider with a Mercrusier engine. When I took it out of winter storage the battery died as soon a I turned on the blower. Since it was a 7 year old battery I went out and got a new one. When I hooked it up switch the cables an it shorted, I went back and got a new one but the only thing that is getting power in the tilt on the outdrive. Under the dash fuses all appear good. Even though it sounds like I shouldn't be touching anything any suggestion where else I sould look before bringing to I shop?
  #2
Old June 9th, 2007, 05:07 PM
gcboat gcboat is offline
Default Re: Electrical Problem
Probably blew the fuseable link. I'm not all that familiar with your setup but the link will be in your main wire bundle, usually covered with massive doses of electrical tape. Just look for an area that is "fat" - should be your link in there. Most automotive stores will carry what you need, no need to pay marine prices. Also, just an afterthought, try to reset your engine breaker. That's gonna' be a red button somewhere around the engine - again - not familiar with your setup. Give it a good, hard push. They're not a dainty creature. You didn't mention if your engine turned over or not. Any running lights?
  #3
Old June 12th, 2007, 11:14 PM
gcboat Thanks for the reply. It sounds like that could be it. The only thing that has power is the outdrive I can lift and lower it. Are you saying that I need to cut and peel back the tape to check the link.
  #4
Old June 13th, 2007, 01:16 PM
No, don't cut anything. I may of been a little hasty on my reply. Did a little searching and it 'may' be something else. Give Bayliner a call @ 877-861-6494. Even though you shorted out something in the system there are too many things that it could be. I'm still thinking some type of fuse, but where it is or which one it could be baffles me. Hate for you to start slicing things apart if you don't need to.
Let me know what they say - be interesting to know the answer.
  #5
Old June 18th, 2007, 10:25 PM
I am all set with this problem. It was the fusable link that was blown but it didn't look like a fuse. The part is located on the starter and it is a square cermic piece the the power and starter wires are connect to. Easy to fix and cheap enough, $20 bucks.
  #6
Old June 20th, 2007, 08:15 AM
Glad you got it all squared away. Next time watch those battery connections.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
electrical problem dhoptay Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 July 17th, 2006 05:05 PM
electrical problem? century4000 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 August 19th, 2005 06:14 PM
electrical problem gijeremy99 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 August 2nd, 2005 05:26 PM
Electrical problem ? crgross1 Mercury & Mariner Outboards 5 June 23rd, 2005 12:37 PM
Electrical Problem? jimmy1587 Johnson & Evinrude Outboards 22 March 18th, 2005 01:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
