  #1
Old June 8th, 2007, 08:40 PM
mschex05 mschex05 is offline
Default painting an aluminum jon boat.
i am repainting my 14' aluminum jon boat and have recently striped all of the old paint off of it. i am planning on washing it with the vinegar/water. after that, do i need to use a zinc chromate primer, or will any self etching primer work? also, do i need to add another base coat, or can i top coat right over that? what about a cear coat, will anything work? i have read all of the other posts about painting aluminum, but i can never really get a specific answer.
  #2
Old June 9th, 2007, 01:00 AM
Rick K Rick K is offline
Default Re: painting an aluminum jon boat.
There are many many many posts on painting aluminum. Did I mention there were many many many many posts on painting aluminum? You said you stripped all the old paint off, so I assume you've gotten down to the bare aluminum. You really didn't need to, but since you're there, here goes..
There's many schools of thought and opinions, but this is what I did:
Yes, use the vinegar/water solution and wipe down the entire boat. Apply two coats of zinc chromate primer, according to the manufacturer's instructions. Now that primer is going to be mighty thick, but you can thin it a bit, again, according to the manufacturer's instructions.
I wet-sanded the primer lightly, and cleaned with a rag dampened with acetone. Once that's done, go ahead and paint with a quality paint. Personally, I used HMG Yacht Paint for the hull, and Petit for the topside (HMG doesn't have the variety of colors as the other mfg's, but is tough as nails, goes on like silk, drys quickly, and goes for about $22/liter).
Now, you can spray, roll, or brush. If you decide to roll, do a search here for "roll and tip", which will smooth out that paint beautifully. I feel HMG smooths out nicer with a roller than any of 'em, but that's just my opinion.
Follow mfg's instructions regarding dry times and wet sanding. I've always waited 24 hours before wet sanding.
As far as where to get the materials, the iboats store is nicely competitive, and has a wide variety of everything you'll need. You won't find HMG there though. Google HMG Yacht Paint and you'll be able to find a distributor if interested.
Barring all that, some guys get great results with 1 coat of primer, and some rustoleum. It all depends what you want.
Good luck
Rick
  #3
Old June 9th, 2007, 09:44 PM
so are you saying that there is no reason to put on a layer of self etching primer before i put on the zinc chromate like i had previously read? also are you farmilliar with metal prep metal primer from pettit. if so is that the kind of thing that i want to use or is there a zinc chromate primer that you suggest?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Painting an Aluminum Boat?!? jburn25 Boat Restoration and Building 9 July 30th, 2007 12:34 AM
Painting aluminum jon boat booboo7353 Boat Restoration and Building 7 February 14th, 2007 09:06 AM
help painting an aluminum boat jwilkey84 Boat Restoration and Building 7 March 17th, 2006 06:45 AM
Painting Aluminum boat mattconlon Boat Topics and Questions (not engine topics) 7 June 22nd, 2004 01:10 PM
painting aluminum boat maddog5203 Boat Restoration and Building 7 October 24th, 2003 08:46 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
