  #1
Old June 8th, 2007, 07:01 PM
imported_stump jumper imported_stump jumper is offline
Default Mariner Ignition Question
I have had some other posts and I am getting close to fixing all the problems from the sinking. I pulled the carbs and cleaned them, replaced a couple of wires that were suspect, replaced the fuel line and went to a portable tank to eliminate fuel problems. I replaced the spark plugs. I fired the boat up and it ran perfect, idled great and was firing on all 6.
I put the cover on the motor, trimmed it up and drove to the boatramp (1 block away) the motor turns over but does not start. I suspect the key switch and I am wondering if there are any wires coming from the engine harness to the switch that would prevent the plugs from getting fire. Is there something that I could be missing? Neighbor tells me to pull the flywheel, I just feel the answer is simpler than that. Please help so I can use my boat this weekend.
  #2
Old June 8th, 2007, 08:34 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
Default Re: Mariner Ignition Question
If you have a wiring diagram and a multi-meter you can systematically check the various circuits to find your problem, or at least eliminate possible causes. Using a systematic approach to confirm you have 12v where there should be 12v, continuity where there should be continuity, and ground where there should be ground should narrow things down. There are just too many possibilities to guess what the problem may be. The shop manual (Mercury or Seloc) for your motor should have a section on troubleshooting electrical.
The below link to a FAQ on this forum may also be helpful:
http://forums.iboats.com/showthread.php?t=158071
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
  #3
Old June 8th, 2007, 08:46 PM
jmburock jmburock is offline
I would suspect the ignition system is corroding away- either the trigger or switch box may be failing. You'll probably need to pull the flywheel in the end- a 5-10minute job with the right tool. I wouldn't go on any far offshore adventures unless you have an entire boatload full of electrical components.
  #4
Old June 9th, 2007, 10:01 AM
Chris1956 Chris1956 is offline
Cool Re: Mariner Ignition Question
If that motor was under saltwater, it likely needs to be disassembled to get the silt and other grit out of the bearings. Also, it is quite possible all the electronics will eventually fail. If you post a year and HP. we could give you a few points to check out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner Ignition CCM1001 Mercury & Mariner Outboards 0 July 22nd, 2006 05:06 PM
mariner ignition timing marcrg Mercury & Mariner Outboards 0 July 29th, 2005 03:44 PM
Mariner 225 EFI Ignition Question coves Mercury & Mariner Outboards 6 September 29th, 2004 04:54 PM
MARINER 8 HP IGNITION COIL JDH Mercury & Mariner Outboards 6 September 10th, 2004 11:30 AM
30 HP Mariner Ignition Problems schuh Mercury & Mariner Outboards 2 October 4th, 2003 10:38 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
