  #1
Old June 7th, 2007, 11:26 PM
MacGyver_74 MacGyver_74 is offline
Default 99 Yamaha 115 2stroke-Carb Starting/Idle issue
Hello all!
I have a 99 Yamaha 115 2 Stroke that is oil injected and carbureted. The boat was dry docked for 2 years with gas in the tank due to the severe drought conditions here in north Texas. We recently took the boat out, drained the gas and cleaned the carbs. The float bowls and jets were not in bad shape, but they had a small amount of gunk and laquer which I was able to easily clean out. I drained the tank and filled it with fresh gas and took the fuel line loose at the motor and flushed the lines with fresh gas.
Now, with a garden hose attached and the other end of the fuel line just laying in a portable tank, the motor started easily and idled smoothly.. Fast forward a week when it is in a slip on the water, and it does not want to start easily. It runs fine at WOT, but does not want to start or idle.. After warming up, it will start if you take it out of gear and throttle it up, but it won't start otherwise.
I noticed the other day that the primer bulb is not staying firm at idle, but even pumping it up firmly does not seem to help it start.
Summary of problems:
Hard to start on first start of day. Even though the primer bulb is solid at startup.
Mushy primer bulb after idling a few moments..
Only will start with medium throttle after it has been running a while
What I have done:
Cleaned the cabs and tank.
put new hose clamps on each part of the fuel lines and squared the hose ends where they may have begun to crack a little from age (I suspected air was getting in the lines).
Could this be the fuel pump or would it run as good as it does at WOT if the fuel pump had problems?
What do you guys think?
  #2
Old June 8th, 2007, 12:47 AM
bugeyestp bugeyestp is offline
Default Re: 99 Yamaha 115 2stroke-Carb Starting/Idle issue
I had similar issue with my 94 150 yamaha. fuel pumps fixed mine. put on a new primer bulb first. primer bulb may break down and restrict flow. good luck
  #3
Old June 8th, 2007, 03:15 AM
JUSTINTIME's Avatar
JUSTINTIME JUSTINTIME is offline
check vent
check primer bulb
test the input and output of fuel pump
__________________
HUMAN BUILT = HUMAN FIXED
CERTIFIED MARINE TECH
  #4
Old June 9th, 2007, 01:57 PM
Thanks for the advice!
How hard is it to get th pump off to change the diaphram? As inexpensive as they are, it may be worth changing it out anyway.
  #5
Old June 9th, 2007, 02:43 PM
JUSTINTIME's Avatar
very easy to do
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
91 Mercury 135HP v6 Starting/Idle issue HELP!! MeatGuy Mercury & Mariner Outboards 1 August 19th, 2006 02:15 PM
repairing or taking carb out of 15 horse yamaha 2stroke tamster61 Yamaha & Suzuki Outboards 3 May 18th, 2005 06:37 PM
repairing or taking carb out of 15 horse yamaha 2stroke tamster61 Non-Repair Outboard Discussions 1 May 17th, 2005 08:05 PM
suzuki 1982 dt28 idle/starting issue wagw Yamaha & Suzuki Outboards 1 March 28th, 2005 10:55 AM
Yamaha 2stroke 115 idle issues Lesiot Yamaha & Suzuki Outboards 2 April 30th, 2004 04:13 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
