  #1
Old June 7th, 2007, 11:03 PM
twigass twigass is offline
Default 140 hp mercury rpms
i bought a 91 bass tracker 18ft and put on a 79 140 mercury with a 19 k prop it runs between 5500 and 6500 rpm and only reaches 48 mph that is gps readings not odometer is that standard or am i pushing too many rpms and is that as fast as it will go, and if not what should i do to get the max out of it
  #2
Old June 7th, 2007, 11:25 PM
OldMercsRule's Avatar
OldMercsRule OldMercsRule is offline
Default Re: 140 hp mercury rpms
My Seloc shows 5300 to 5800. I doubt an occaisional burst to 6000 would hurt much, but 6500 seems like yer turning too much. JR
__________________
A proud n' rare Independent Cornservative from the Seattle Metro area, who runs the finest old black boat anchors money can buy!
  #3
Old June 8th, 2007, 01:52 AM
Clams Canino Clams Canino is offline
You Seloc is showing you the RPM range to PROP it for. This is to set the correct loading (gearing) for the overall package of boat and outboard.
It's not telling you to actually *run* it like that on a regular basis.
PROP IT FOR 5500 - CRUISE IT AT 4200
-W
  #4
Old June 8th, 2007, 10:00 PM
thanks for the help. but still a little confused i am new at this so bear with me, people say it should go about 60 is that right or are they blowing smoke up my butt, and can that motor handle premium or no and 50-1 is that good for an older motor. also what brand of plugs do u rec for that i have champs in it now flat bottom style. the props also the 1 is a 2 phase pitch and the other is just a big pitch, i dont get rpms out of it like the other about 5000 for big pitch and 6200 for 2 phase also 2 phase gets 48 and other only 42. tach is off a little around 500 so they r a little off.any help is good help
  #5
Old June 9th, 2007, 01:28 AM
60 is not right. Champion or NGK are good- yes they are flat bottom - that's correct for the inlines. You need a 5500 RPM prop (something between the 2 you have) and then *run* normally it at 4200. If you just want speed, buy a new motor and blow it up under warrantee. the old inlines are all a worn a few thousanths and WILL blow up under extended WOT use. I live on a 3 acre, lakefront home because people run them at WOT.
-W
  #6
Old June 9th, 2007, 06:06 PM
Scaaty's Avatar
Scaaty Scaaty is offline
HA!
  #7
Old June 9th, 2007, 06:49 PM
Quote:
HA!
Me thinks Wayne has a rather large n' very valid point that he put in a very profound way: Scaaty!! I only have enough faith in one of my inlines to hot rod very much, (n' I don't do it cause it's 38 years old and I would hate to have to get another one). You strike me as an ol' rodder who would understand the very valid corncept he states here. You're fresh 1350 should be good fer some serious roddin' once broken in!! JR
__________________
  #8
Old June 9th, 2007, 09:02 PM
thanks for the help guys didn't really want the speed but everyone telling u something diff is what confused me so i appreciate itvery much and will go back to original prop and have fun
  #9
Old June 10th, 2007, 04:37 AM
Yes... you PROP it for 5500 or so WOT - the speed you get is what you get.
Daily cruise outta be at 4000-4200 - the speed you get is what you get.
-W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 60 that alarms at or above 5400 rpms Jack Magnum Mercury & Mariner Outboards 1 July 24th, 2005 12:38 AM
78 1150 mercury cant reach rpms help!! 1150 mercury Mercury & Mariner Outboards 1 July 11th, 2003 11:55 PM
93' 175 mercury will not go over 2000 rpms? ranman Mercury & Mariner Outboards 1 July 2nd, 2003 03:38 PM
Limiting RPMs on Mercury David R Mercury & Mariner Outboards 3 July 16th, 2002 08:33 AM
115 Mercury 4-Stroke - no RPMs motorman Mercury & Mariner Outboards 4 May 10th, 2002 06:26 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
