Im boatmoter
- May 9, 2007
- 2
I Can Not Make Heads Or Tails Out Of The Directions From My Repair Manuel To Set The Timing On My 79 Rude 140,did Not Feel Safe With It. Don't Want To Overhead Or Ruin This Rebuild.i Trust You Guys More Than My Inturpetation Of The Manuel On This. I Rebuilt It .,it Has Around 2 Hours On It. Also Need To Ask,someone Told Me I Could Leave The Boat On The Trailer And Strapped Down And Back It Into The Water,hold It Full Throttle And Set Timing,would You Recommend This?? What Is The Correct Steps And Technique For Setting The Timing And Throttle Cable And Gear Shift Cable And Idle Rpm's And Syncing It All Togeather? Also What Is The Maximum Rpm For Ths Engine? The Settings Are Total Off,tryed To Adjust Everything To Get To Idle Before I Found Out It Had Low Compression,its Now Rebuilt And The Settings For Everything Are Out Of Wack. It Ran With No Missfire And Smooth,ran Cool,but It Would Not Wind Up,it Felt Like The Timing Was Way Retarted.it Should Respond Quick And Wind Up,its On A Light,17 Ft Tri Hull.
Appriciate Any Help..
