hkeiner
- Oct 17, 2006
- 1,055
This may be a silly question, but can a variable speed angle grinder be adapted to be used as a polisher, similar to a the Porter Cable 7428? Angle grinders and polishers look very similar in appearance if I remove the shield from the grinder. I can imagine that one problem might be in attaching the polishing pads to the grinder if the the method of attachment is different between a grinder and a polisher. I don't have a polisher to look at in order to check this.
The reason I am asking is that I already have an angle grinder. I also have an orbital polisher, but have read that one should use a polisher with glazes and polishing compounds. I would like to try a regular (non-orbital) polisher to see how that works in shining up the gelcoat on my boat.
Thanks for any opinions.
