· Does anyone know where I can find the above part, new or used ?
· I think I may have bought the last one a couple of years ago. 2 weeks after I installed it I found it laying in the bottom of the cowl with the short cable broken (just like the old one). What could be causing this ? Is there supposed to be something to keep the plunger from falling out of the solenoid ?
· Does anyone have another solution ? I'm frustrated with having to remove the covers every time I need to manually choke the engine................
i think any complete choke solenoid, that will fit in the space would work, all it does is pull the choke linkage. is your mounted above the carbs at the top of the engine. if so any solenoid off and inline 4or 6 should replace.
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Can't help you find one but I recently swapped a bunch of parts from a 75 to my 66.
I noticed that the choke solenoids used different diameter plungers.
I can't remember which used which but perhaps the plungers you are using are too small in diameter which is causing them to fall out.
__________________
1974 Glastron V-179, Mercruiser 140
Evinrude 8hp 1993 kicker
14ft. Alumimum fishing thing with 82 Merc 50
Homeport - Lac du Bonnet, MB, Canada
I've used Fram oil filters in all my junk for 35 years-no problems
saw one e bay last week, mine did the same and i made a small copper wire to fit from sol to choke and kept bending it with needle nose till i got the right amount of throw. it the sol doesnt remain mostly in the housing it will fall out. gary
