update on 225 Ficht with major problem
2000rsvr
Hi guys
Thanks for your help so far, but I still can`t figure this out. The engine starts rigth away, but it runs very rough. It idles at 2500 rpm (??) and there is a lot of boubles coming out at the gearcase (water is "boiling"). Did a copression test, and all were between 110 and 118 pounds. The plugs are new.
When it happend, I did notice that the engine started to run rough (shaking), and it got worse the next 5 minutes.
Any of you experts out there got an idea?
muskrat
Re: update on 225 Ficht with major problem
get a service manual & check the lift fuel pump.
