roger3645
- Aug 30, 2005
- 271
Just received two used 8 pin merc controls with the warmup lever. Just the control boxes and wiring harnesses no cables. I cannot get either control lever to move into the forward gear position. Is this some sort of safety feature as not to start the engine with the motor in gear??? The controls are not connected to a motor just pulled them out of the box and tried to work them thru the gears. Is this how they should work or did I buy junk????
Thanks Roger
Thanks Roger
