  #1
Old June 6th, 2007, 09:57 PM
adegiulio adegiulio is offline
Default A recurring starter problem gets worse...
One of our recurring problems is when I go to start her up, I get nothing but a click. The battery is new and fully charged. Everything else works fine (blower, bilge pump, etc). Today, I decided to try to tighten things up on the starter (or at least knock off any corrosion). As I turned the wrench, I got a nice spark as the metal touched the housing of the starter (a careless mistake I won't repeat). Now, I get nothing at all, as if a main breaker has tripped. I found a breaker reset switch on top of the engine (the boat is a 2001 Searay 190 Bowrider, the engine is a 4.3l Mercruiser), but pushing the button to reset did nothing. I disconnected the battery (something I should have done at the start) and reconnected it, thinking the breaker might be caught in some sort of electro-magnetic limbo. No help. So now, everything is dead, except for the pump which raises and lowers the sterndrive.
Any hints on what I might be missing? Is there another breaker somewhere? Are these breakers prone to failure? It seems like I am missing something very simple, but being new to boats, I can't figure out what it is...
Thanks in advance.
  #2
Old June 10th, 2007, 02:25 AM
magster65's Avatar
magster65 magster65 is offline
Default Re: A recurring starter problem gets worse...
If it's not a bad connection somewhere, the 'click' was/is likely the starter solenoid.
Your newest problem might be... my '03 boat has a main fuse panel under the dash that has a master reset on it, maybe yours is the same? You can check all your other fuses when you find it.
Let us know how you make out.
  #3
Old June 11th, 2007, 07:28 AM
I also posted this question in the Mercruiser thread. Turns out I blew a 90A fuse that I never would have realized was a fuse without this board. While I have a fusebox under the dash, there is no reset. Changing that 90A fuse did the trick. Now I need to figure out what is wrong with my starter...
  #4
Old June 11th, 2007, 10:58 PM
magster65's Avatar
Excellent! I wonder if that's the same feed but changed to a breaker instead of a fuse in '03?
Gotta' love the information that's available on this site... it's amazing!
  #5
Old June 18th, 2007, 10:02 AM
mkfs9 mkfs9 is offline
HI i had a similar problem on my 4.3 v6.It turned out to be the pre solenoid.this is not on the starter but on top front of the engine behind the reset button.Cheap easy fix.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Water pump problem or worse? huntero Johnson & Evinrude Outboards 1 November 22nd, 2005 01:54 PM
Problem with OMC sterndrive getting worse David Kraus Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 August 8th, 2005 10:21 AM
Horn alert on '94 Johnson 50 - recurring problem johnny1 Johnson & Evinrude Outboards 0 June 10th, 2004 09:18 AM
Could it get worse? jailermac Stupid Human Tricks While Boating/Fishing 5 May 19th, 2004 09:32 AM
Recurring Problem BoatingGirl Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 March 27th, 2003 03:57 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
