  #1
Old June 6th, 2007, 12:10 PM
SAGENT SAGENT is offline
Default Honda Bf40 & Pontoon Performance Issues
I have a 20' Misty Harbor ponoon with a 2001 Honda BF40 with a 12.125" x 9"
pitch 3 blade prop. At WOT the tach shows about 3900-4000 RPM. The manual for the outboard indicates it should be running anywhere from 5000-6000 RPM. I see on Hondas website the smallest pitch prop for this engine is a 7". The pontoon we had previous to this was a 18' Misty Harbor with a Honda BF25 with a 12" pitch prop that seemed to have similar performance as this one. The BF40 does not start or run very well when cold but seems fine with engine warm. The BF40 has maybe 100 hours on it and new plugs just installed. Anyone have any ideas on where to start?
  #2
Old June 6th, 2007, 02:34 PM
zzzzz zzzzz is online now
Default Re: Honda Bf40 & Pontoon Performance Issues
looking through the parts diagrams,it appears you have a manual choke...what is your starting procedure?...as far as the tach goes-you need to check the settings on the back of the tach to make sure it is set correctly then look for a prop problem
  #3
Old June 6th, 2007, 03:16 PM
steelespike steelespike is offline
Assuming the engine is sound and throttle opening fully I think I would start by raising the motor vertically.I saw a specs on a 50 etec on a 23 ft toon running a 13 3/4 X13 prop turning 5,375 at 19.5 mph.
I would think your 40 on a 20 should approach 5,000 with a 9in prop.
Something is amiss hopefully just the setup.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
98 Honda 90HP 20' Pontoon PROP ISSUES MuskyHunterDave Honda & Tohatsu/Nissan Outboards 6 March 13th, 2006 09:23 AM
Honda BF40 Carb Leak sailsman Honda & Tohatsu/Nissan Outboards 6 July 25th, 2005 06:54 AM
tachometer on a honda bf40 whatda Honda & Tohatsu/Nissan Outboards 1 May 23rd, 2005 02:38 PM
Honda BF40 Carb Question PlanB Honda & Tohatsu/Nissan Outboards 2 April 2nd, 2005 02:18 AM
Honda BF40 & 50 landLocked Honda & Tohatsu/Nissan Outboards 1 August 27th, 2003 08:24 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
