I have an 89 Mariner 75 3 cyl (ser #OC170850) which died suddenly at the end of the season last year after running flawlessly. I've found that no spark was present at all 3 cylinders. I found that one of the trigger leads (white) was completely disintegrated. Replaced trigger with brand new one. Still no spark at no cylinders. I isolated out the mercury tilt switch/harness/ and regulator and this makes no difference. The stator (red stator upgrade) ohms out at 675 (range 500-700). My question is: could the broken trigger have taken out the switch box?? could the stator or the black adaptor attached be at fault causing the no spark condition even though the stator ohms o.k. Do I need to retime if I replace a trigger or would this even cause a no spark condition if timing is off? Would a burned out switch box cause no sparks if everything is o.k. I'm stumped at this point. The rusted out lead on the trigger looked like the only problem, but I guess there is more...
Any advice is greatly appreciated. This ignition system seems to be problematic in these old Merc/ mariners..
