Re: Mercury 200L EFI Water Pump
OK I got it put back together but I have water comming out of everwhere except the pee tube. Seems like the rubber seal to the copper tube off the top of the pump housing is leaking. Is there a trick to getting that back together correctly? I put the seal in the housing then put the plastic tube into the housing to line up the copper tube. I seems to be leaking around that.
